I talked to zooomer at zzperformance he said if we get 7+ people that get about the same programming he will charge us 300.00 instead of 450.00. I know most of you guys are just like me and want to raise rev limiter remove governer, set shift points and so on. Lets get atleast 7 people in on this. Zooomer told me he has a thing that is way better than the maft+ and does the same things which is adjust timing and fuel. It is called the iccu in car control unit. He also told me that his mini afc will let you adjust your computer so you can run bigger ine=jectors, i just figured i would let you guys know about this.
ZOOOMER AT ZZPERFORMANCE WILL PROGRAM 96-97 COMPUTERS :)
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
<blockquote>quote:</font><hr>Originally posted by Nachius:
Yay I'm all about all of this I want all the stuff you mentioned above and a reprogram from 3.08s to 3.42s you think 1 little change like that would still fall under "about the same Programming"?
How do we get in contact with them?<hr></blockquote>
You might as well take off the speedlimiter and raise the rev limiter while you're at it - you might need it later :D2002 5-spd NBM Camaro
Details: www.1lev6.com
Maybe we should just send death threats to the people at hypertech and tell them to make a programmer for our cars... OR ELSE! That way I wouldnt have to drive all the way to Ohio (I'm assuming thats where zzperformance is?).<b>Black 1996 3.8L Firebird A4</b><br />--------------------------<br />Custom CAI, Flowmaster Dual Exhaust, 160 Deg Thermo, BMR ShockTower Brace<br />JVC mp3 HU, two 12\" Infinity Kappa Perfects, Infinity 6.5\" components, JBL 600.1 & 80.4 amps <br /><a href=\"http://community.webshots.com/album/479229363CPbPiz\" target=\"_blank\">Pics</a>
why would you drive? all you have to do is send them your pcm. i doubt that would be out of the catergory, im sure its close enough [img]smile.gif[/img] ok well thats two for sure come on 5 more for the 300.00 price. any other guys willing to commit? i will just forward the names to him after we hit atleast 7 i hope this works out.Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
Sounds like a god deal, but...How much hp increase are we talking for this reprogramming?
Don't get me wrong, I'm happy that we 95-97 3.8'ers finally found someone to spice up our computer, I just would like to get a pep-rally going in my head so I can squeeze the money up faster from the/our wedding bank account. (shhhhh!)
Marcsigpic
Not sure on hp but with the shift points fixed you will gain so much in the 1/4 plus with the benefit of having a raised rev limiter and no governer that wll truely be a unique experience, gonna be awesome not peggin rev limiter when you hit the juice [img]smile.gif[/img] so who is all ommited so far i believe we have twoLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
I'm in once I get full details. My shift points are killing my 1/4 times. I'm also banging the rev limiter on rare occasion and am tired of messing with the scu2000.
Send me and email and let me know full details please!
[ October 22, 2002: Message edited by: Nachius ]</p>
what about M5's. Will he offer the same deal for us? Of course I don't want shift points, but speedo, rev and speed limiter could be gone.1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
AZ, what do you need done? I may be able to help you out for much cheaper. ;)
I really want to help out guys like you.. who don't have $450 to spend on programming.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Then Magnus, you want to help me as well [img]smile.gif[/img]2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
What do you want done? I am just starting to look at the 00 +'s.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
magnus i have a 00 and i will need comp programming can u IM me and let me know what you can do and how much it will cost i might be willing to send u my pcm my AOl name is crappyday21<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
