1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
crower has better cams then that the baja cam and the one up from that will be a good cam for you i think. if your not wanting to go all out i would suggest one cam up from the baja i have talked to someone with the baja they said it's nice and anyone who gets a cam might want to try one stage up they would have no probs. with emissions or anything i was going to get the bigest one they had but i went custom grind it's on the way now he he i can't wait
226/236 .494/.506 112ls 1.6 ratio
[img]graemlins/burnout.gif[/img]
<blockquote>quote:</font><hr>Originally posted by southern94: crower has better cams then that the baja cam and the one up from that will be a good cam for you i think. if your not wanting to go all out i would suggest one cam up from the baja i have talked to someone with the baja they said it's nice and anyone who gets a cam might want to try one stage up they would have no probs. with emissions or anything i was going to get the bigest one they had but i went custom grind it's on the way now he he i can't wait
Assuming you have a stock car and that the Crower #s are @ .050" lift, then this is what I got from DD2000. #1 is stock,#2 is the cam in question and #3 is the crower cam. Hope it helps.
From those numbers I kinda like the jegs cam cause there's more torque across the RPM band. Now is lift everything in a cam? Cause I saw the crower cam had alot more lift than the jegs one. But like I said, I like the jegs cam's power curves better.
Hey lando, can you give me a breakdown of all the numbers (especially the heads numbers) you put in Desktop dyno? I got a copy and need the head's flow numbers.
i want to put those jegs cams on mine. i asked around and people said it would sound funny, ricey even. is this true, i dont think it is...? i want em tho, should i do it. and will i have a good noticed difference. numbers show a difference; hope they do in my car also...
thx
--pete
<b>RIP:</b> 1995 green firebird <br /><br />\'00 bird soon to come...
