Transmission Question - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • Transmission Question
    How can you get the 4L60E to support a turbo, heads, cam, and all the other valve work I'm doing?
    Changing the torque converter? What good does that do? And what else is there to be done?
    Your tranny will run fine without making any changes to it.
    A torque converter will help you at the track and is a pretty good idea, but the trans won't explode if you don't do it.
    I really think you need to do some searching before posting dozens of questions like this.
    Moving to Drivetrain....
    Matt
    1998 Mystic Teal Camaro M5
