Pleaseee, pleaseee help..!!! can a sbc roller rockers fit in a 3.4?
I understand "All 60* rockers are nothing more than SBC rockers with modified balls,Where do I get the "modified balls" or the "narrow body rocker" (can I find these at eBay???).
The modified balls are already on my engine, they differ from the SBC ball only in the hole that is drilled in them..!!!??? ,So if i buy a SBC roller tip rocker they will work just by using my stock rocker ball.???
Can i pick up a cheap set of SBC rockers at eBay and use the stock 10mm rocker balls...????????????????????????????????????????
"Cheaper than the Comp Cams Magnum rockers and they seem to work as well"
