Ok here is my planned build. I have an 02 38L bird. It is not super wild. Just working to get a few extra reliable, streetable, hp. I need to keep it tamed down a bit as I drive my car every day. Not looking to break any land speed records here. LOL. I’m looking for some suggestions. Some items I do not have part numbers for, and I’m not where to get them. (i.e. Jegs, summit, etc) Or if anyone has better ideas etc?
AM Performance Comp cams 200/206 grind cam part # 76-801-9 $286.25
Cam specs:
200 intake / .498
206 exhaust /. 480
Lobe Separation 112
Intake centerline 108
Summit Racing Comp cams springs part # 26918-12 $141.39
1. 12 Rocker Arm Bolts <-need part number is it necessary to replace these? ARP Brand?
2. 2 Valve Cover Gaskets <-part number? Brand?
3. 1 Intake Manifold Gasket Set <-I think I have this one listed below from GM parts direct.
4. 1 Front Timing Chain Cover Gasket <-part number? Brand?
5. 1 Crank Pulley Bolt <- need part number is it necessary to replace these? Brand?
6. 1 Cam Sprocket Shaft Bolt <- need part number is it necessary to replace these? Brand?
Intake spacer $120.00 http://ww2.netnitco.net/users/cheetah/g3023.html
½ inch intake spacer using 2 intake gaskets top and bottom. <- not sure if this will help or hurt. Suggestions? Just figured while it is apart might as well add the spacer. Will this extra ½ inch clear the BMR shock tower brace? I think it will? Any advantage to custom fabricating my own aluminum one that is taller. (i.e.1 inch )
Stock intake Gasket part # 24504789 9 $9.00 GM parts direct.
Raise compression ration from9.4:1 to 10.5:1 Is this safe for 91-93 octane pump gas? What size pistons should be used? Part number? Brand suggestion? I had thought of using some lighter stronger connecting rods as well. I have read on here that our 3.8L engines can not be bored due to hitting water jackets.
With this set up I am guessing I should have no problems with needing bigger injectors, TB, or computer tuning. If anyone feels this is needed please explain why. I am open to any and all suggestions. Please feel free to comment. Could anyone roughly guess what expected gains from this set up should be?
The only non-stock items are:
1. 2.5 inch SLP Stainless Kat-back exhaust.
2. Whisper Lid.
3. Whisper C.A.I.
4. K&N Filter charger.
Thanks in advance for the help.
PS if this is not considered to be “advanced” material feel free to move this to the appropriate channel. My apologies if this is not the correct forum to post.
Cam specs:
200 intake / .498
206 exhaust /. 480
Lobe Separation 112
2. Whisper Lid.
3. Whisper C.A.I.
