I just bought my Comp Cam w/ 120* LSA. I plan on Comp Hydraulic lifters, new rods (Comp I guess) and possibly anything else worn in the valvetrain. I do NOT want to run new rocker arms. I will switch to a hotter plug as well. Since this is a mid-high end cam I figured a 3.73 gear ratio would go with it. What are your thought on building and appropriate driveline to complement each mod. Thanks.
Need advice on the setup...
That sounds like too much cam for stock heads....I would do a 5 angle valve job and some porting if I was doing it on a 4thgen...engine bay is cramped as helll...You might as well pull the motor out to make it easier ( I would ). If I hada 4thgen, EVERY mod would be engine outside of car (especially changing injectors!). [img]smile.gif[/img]MODS:<br />3.4,Crower cam, K-motion valvesprings, Heddman Longtubes, BBK AFPR, Accel Coil, 36mm/23mm Sways, Boxed LCAs/Panhard bar, Mutant Nitrous wet kit, Mr. Gasket Cutout, 10.02 1/8 mile at 67.2 mph UNTUNNED no spray
