Fuel Pressure - FirebirdV6.com/CamaroV6.com Message Board
Fuel Pressure
  • Fuel Pressure
    Does anyone know what the stock fuel pressure is on a 3800 when the car is idling?
    92 S10 2.5<br />3800 Swap under construction!<br />New SN: RedFrk13
    48-55 psi (ignition ON)
    3-10 psi loss at idle
      ~42psi idle
      ~50 psi WOT
        Thanks!
