Cam is in...what a difference - FirebirdV6.com/CamaroV6.com Message Board
  • Cam is in...what a difference
    I finished my cam install tonight on my 3.4L...what a HUGE difference. No more dead top end. For those of you who don't know the specs are:
    Lunati Custom Grind Cam
    Lift: .496/.496 w/1.6 Rocker Arm
    Duration @.050": 228/228
    LSA: 110*
    +4.0 Timing Advance
    Cam runs absolutely awesome and there was a tremendous increase in power expecially in the top end...my main problem is keeping the thing running at idle. Looks like I may be doing a little drilling on the throttle plate.
    Oh, another problem was the SES light, but that was expected.
    What insane specs those are! Lunati does custom stuff? Can they make me a 3.8L grind?
    How long was the install, any pics or guides you might have for 3.4 guys? Great job, btw.
    Scott
      I have contacted Lunati and they have nothing available for the 3.8.
        sweet i got mine in the mail the other day fri. along with everything else thanks josh
        cam specs
        226/236 .494/.506 112ls
        everything looked great thanks agian
        you need to go run at the track agian see what a diff it made
        1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
          What would be a good grind/cam for a 3.4 but avoiding the idle and SES issues?
          Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
            sweet [img]graemlins/thumbsup.gif[/img]
              Lunati makes at least 3 custom grind cams for the 3.4L and I think the same number of shelf cams. There is a lot to choose from on the 3.4L side of things. I will talk to my sales rep at Lunati to see what he could come up with for the 3.8L guys.
                nice! I also need to do a cam. What was involved in the install?
                Josh-
                \'94 Camaro A4<br />Mods: K&N Conical, Dynomax Muffler, Dynomax 2.5\" I-Pipe, Jetchip Stage II, 180 Stat, RKSport Underdrive Pullies, Fan Relay Switch, Rapidfire Plugs, Bosch O2s, Goodyear GA, Aluminum Driveshaft, Alpine CD... <p>And also: Ported and Polished Plenum, Ported and Polished Intake Manifold, Ported and Polished Heads, 5 angle valve job, Raised Compreshion, Tranny Cooler, 19lb injectors, no new times yet.<p>\'95 Dodge Stealth M5<br />stock as a rock...
                  Removal on radiator, cooling fan, crank pulley, harmonic balancer, water pump, accessory brackets, upper intake manifold, lower intake manifold, lifters, oil pump drive gear, lifter, pushrods, front engine cover, cam gear, timing chain and then cam. Oh, and then it's a good idea to put it back together to get it to run.
                  [img]smile.gif[/img]
                    How much did the whole thing cost with parts and labor included???
                    E-mail: ibjanky@yahoo.com<br />AOL IM: IBJanky
                      Under $150 for the cam, labor was free, gasket sealer and gaskets, maybe $30. All included, less that $200.00.
                        wow, wish I had the guts to tear down my motor like that.
                        -Steve
                          It's not a bad tear down. I did it twice. With the right tools it can be done over two days. But, i think ti will cost a bit over 2 bens though. Is the Lunati CAM a kit? If not you would want to replace the lifters while in there IMHO. I assume the CAM comes with lube. You have at least 4 gaskets to buy (upper and lower intake, timing chain/water pump cover, valve covers). After running the CAM for a short period you need to change the oil and you'll lose some coolant.
                          All in all it's stillnot that much to do.
                          94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
                            So your car doesnt has trouble with running idle now?
                              It idles very rough and it has a little trouble staying started when the engine is cold, but all you have to do is feather the gas a little. I may drill a SMALL hole in one of the TB plates to keep the idle up a little...that's what we had to do on the Vette when we did heads and cam on it.
