would these give any thing for hp or tq? i did a search and it looks as if every one thinks they would only give 3 tq and 5-6 hp, but the stats stated on the advertizment was for up to .2 off of your quarter mile times
and with a stock cam would this cause a small lope in sound or is that from duration?
91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
it'll give u more hp/tq if u already have ur intake and exhaust modded out. it may drop 1/4 times .2, but that's dependednt on a lot of other stuff 2, such as traction from the newly aquired hp, launch technique, reaction time, weather conditions, ect. it'll increase lift mainly, but also give u a little longer duration and more overlap(which is good for NA cars but not so good on forced induction cars). it's a cheap way to make ur car seem bigger. if u keep them and plan on getting an aftermarket cam in the future, u'll have 2 tell them that ur gonna use the cam w/ 1.9:1 ratio rockers.
FYI: Those work pretty well on the L67(10-15hp) conservatively. But on the L36 many people have found that if they use a 1.75 on the exhaust side it helps the bottom end. ZZP sells split ratio rockers for the L36.
