Can the pcm from an automatic trans 3.4L be used in a car with a manual trans? I've run into some fuel problems and arrows are pointing towards the pcm. Just wondering if it would work.
PCM swap question
PCM swap question
1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuningTags: None
The 94-95 automatics carry a different service number than the manuals from the same year, however it appears that you can run the car with an auto PCM although it will set error codes because of the missing electronic transmission parts.
http://www.camarov6.com/cgi-bin/ulti...;f=16;t=002787
(see last post)1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
