well imthinking about buying the stroker motor 4.1l for sale. he thinks a rod bearing is bad. hos much will this cost to replace? also would i be as fast as an lt1 z? i figure it should spank an lt1 z. do you guys have any knowledgable opinions? thanks
ZZP 4.1 stroker kit
Hypereutectic recessed head pistons
Molly rings
ZZP high oil volume kit
Magnafluxed block with balance shaft removed and oil feed hole plugged
ARP main stud kit
ZZP stage 2 Port and Polished heads with upgraded 130# springs
Comp OER lifters
Comp Cam rods
Comp Cam GT3 cam
Harland Sharp roller rockers
Port and Polished upper and lower intake manifolds
Pacesetter Headers
Intense stage 3 computer
TCI 3000 stall converter
Rebuilt street/strip trans
Clevite bearings
Victor Reinz gaskets
Also:
Would I need to make any fuel system upgrades if I swapped from a 3.8 to the 4.1 stroker?
[ November 15, 2005, 03:07 AM: Message edited by: AZ3.8Camaro ]
ZZP 4.1 stroker kit
Molly rings
ARP main stud kit
Comp OER lifters
Comp Cam rods
Comp Cam GT3 cam
Pacesetter Headers
Clevite bearings
Also:
