Injector flow chart - FirebirdV6.com/CamaroV6.com Message Board
Injector flow chart
  • Injector flow chart
    I was wondering if anyone can get the flow rates for these injectors from this chart:
    100%duty CycleF 3ms@5000 rpm 12ms@2500 Ohm/cutoff
    1.195cc----58ml---25ml---------32ml--------12.0
    2.195cc----58ml---25ml---------32ml--------12.2
    3.195cc----57ml---26ml---------32ml--------12.1
    4.195cc----57ml---25ml---------33ml--------12.0
    5.195cc----58ml---25ml---------32ml--------12.0
    6.195cc----57ml---25ml---------32ml--------12.1
    Duty Cycle:tested@40psi for 1 minute
    Cycles F,6,5: Tested@40psi for 30 seconds
    Total system: Lbs/hr - 111.28
    Now,for 6 injectors is this saying they are 18.5 lb.ers?
    [ September 20, 2003: Message edited by: Coriya71 ]</p>
    95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
    Yeah, 195cc is 18.5lbs. Are those off of your car??
      If they are that means the 3.8 in 1995 had some mightly tiny injectors...
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        No, [img]smile.gif[/img] A few years back I bought set of those Venom performance injectors that were supposed to "flow 10% more fuel". Well, I got them hella cheap but never put them on, they've just been sitting. Well, I got a new motor to drop in and was looking at this chart and them our tech database, and thought something doesn't jive. So instead these will probably go to ebay for someones Beretta and I'll try to find some 26# LT1s. Thanks guys for the help! [img]graemlins/thumbsup.gif[/img]
