I have purchased a Intense Stage I Cam, Intense 1.6 Roller Rockers, Intense Pushrods, Comp Cam Valvesprings and retainers to install in my Camaro. Will the stock lifter work with this set up? I want to avoid pulling the heads.
Cam and Valvetrain Install Question.
2001 JET BLACK V6 CAMARO <br /><br />-Powerdyne Supercharger, Pacesetter Headers, Transgo Shift Kit, and a whole lot more. <br /><br /> <a href=\"http://groups.msn.com/SPEEDSTYLEandPERFORMANCE\" target=\"_blank\">http://groups.msn.com/SPEEDSTYLEandPERFORMANCE</a> <br /> <a href=\"http://www.cardomain.com/id/camarostallion\" target=\"_blank\">http://www.cardomain.com/id/camarostallion</a>Tags: None
I believe the stock lifters will work as long as you don't rev higher than ~6000 rpm.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
Stock lifters aren't bad at all. New ones are good just so you know that there's nothing wrong with them, but you'll be fine with the stockers. I'm actually back on my stock lifters now while trying to find a tick.
Like ma4life said, if you do want to install new ones, you don't have to remove the heads.Matt
1998 Mystic Teal Camaro M5
