which tuning is better the 87 tuning or the 93 honest opinions on the matter please just curious on which one works better. i know someone said that 87 made more but that was one guy i want to hear everyones opinion on this
hpp3 question
i also have mine set at 93.<b>2000 Firebird </b><br /><i>old setup </i>- Automatic Whisper lid, Borla catback, shift kit w/ V8 servo, 3.42 gears w/ LSD, PI 3000 converter, <br /><br /><i>14.703@90.92, 2.01 60\' </i>(intake and exhaust)<br /><br /><i> new setup </i> swapped over to LS1 413.9rwhp/398.7rwtq<br /><a href=\"http://www.thunderracing.com\" target=\"_blank\">www.thunderracing.com</a>
I have mine set to 87, it made a noticeable increase. I won't try 93 until I can prove its a lot better than the 87 tuning on the dyno or at the track.
According to hypertech's dyno, the 93 is only like a 1-2hp gain over the 87 tuning... not worth the $0.20 increase in fuel per gallon IMO if thats the case.2002 5-spd NBM Camaro
Details: www.1lev6.com
what was the gain like dominic? i plan on getting it to adjust the speedo b/c of gear change and new wheels, but i was hoping to also see a little bit of power from the 87 octane tuning. thanksblack 2000 camaro v6<br />GTS blackouts, 20% tint all around, clear corners, Panasonic Head Unit, Whisper lid & Whisper ram air, 3.42 gears w/ LSD, 3\" Edelbrock Catback, Mac SFC\'s, Milhouse box from Subthump w/ 12\' Kicker SL7<p>LIFBA Member #044 <br /><a href=\"http://www.lifba.com\" target=\"_blank\">www.lifba.com</a>
I havent track tested it or anything but it does seem to pull through the gears faster. If you read some of my posts in general tech you'll get a better idea.
I like the programming, it seems stouter and peppier with it. Ive purposely programmed it stock and then back programmed a number of times to see if I could tell a difference and its noticeable but nothing outrageous. Highway interstate pulling is about the most noticeable one I've found when I ran a few 60+mph pulls against my friend in his Acura TL [img]smile.gif[/img]
Im sure with full exhaust it would be far more noticeable, programming cant compensate much for a 2.25" exhaust constriction :D2002 5-spd NBM Camaro
