i got the motor still in my car.. the top half has ben removed. (intakes, cam, valvetrain, etc) can i pull this thing from the top or does it need to come out the bottom.
also the motor is sezied so i can't remove the tranny. i think i'm going to try to pull it from the top with the tranny still atached.
97 CAMARO RS<br />12.9@103mph<br />best 60ft..1.9 ( on street tires)<br /> 1.7 (on gas)<br />turbo supra 12.5@119mph (street tires)<br />new times to come sporting the sp63gt
ive seen a few 4th gens with the motor removed via the top, as long as you have a cherry picker its not that dificult if you take your time to make sure you are pulling it out without snagging anything
was that with or without the tranny attached. i have a picker and i have pulled motor before but this one looks like it's going to be a good size task
