Ok, suppose I blew my motor and wanted to replace it with another 3.8. Would it be possible to put a newer 3.8 in like say 2000 thru 2002 in? If so would the newer PCM allow you to use the Hpp3?
Engine swap
<blockquote>quote:</font><hr>Originally posted by Scott Black:
[QB][/QB]<hr></blockquote>
He need to use all of the units that came with that new engine since he's planning to use the 2k-+ PCM also. BTW, 2K and up engines have electronic throttle system.<i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
I'm assuming he is buying a longblock, including wiring harness and PCM, which will take care of that.
Scott
Edit: Your transmission's bellhousing is probably different then that of a 2000 model, so you will have to buy the trans as well and swap that in. I completely forgot about that.
[ October 31, 2002: Message edited by: Scott Black ]</p>
