ok is it possible to swap a 91 LT1 motor into a 98 camaro that has a 3.8 in it? if so how hard is it to do to make it possible and is it worth it? and around how much horsepower does a 91 LT1 make because i know from 93 to 97 the LT1'S made 280.
i came accross a deal for a LT1 that has 80k on it and comes with the computer and all the wires for $800
Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
i believe in 91 they were still at 280 hp..the vettes were at 300 hp..so its probably good for 300..you're also going to need the transmission, front suspension to hold up the V8, and the radiator because i think its reverse flow (not sure about that though)
