I am finally ordering my double roller timing chain/gears, and I am replacing the oil pump while I am in there. So I figured I might give the high volume kit a try.
If you use one, how do you like it? What pressures do you see? At idle and at WOT.
1997 Dodge Viper GTS
Those guys at clubgp seem to have the same opinion I have about it. On the fence.
My oil pressure runs right at 30 at idle and just barely to 60 at throttle with 10w-30 in it.
When it was newer, it stayed at least at 60, even at idle. It just seems like it's too low for me. I know the oil spring mod doesn't help idle oil pressure, but I would really like to see more WOT pressure.
I am theorizing that maybe some chunks of my timing chain tensioner have damaged the pump, etc. But I think I need to change out the Oil pressure sending unit first, then go from there.
Matt, since you are king of part numbers, do you have a GM part number for the bolts that hold the oil pump cover on? They tried to strip out last time I replaced the timing chain (when I wanted to check the pump out) so I left it alone. This time I will replace the pump/plate/bolts.
Originally posted by AZ3.8Camaro: Those guys at clubgp seem to have the same opinion I have about it. On the fence.
Geeze, I dont like it when my car idles a couple ticks below 60. [img]graemlins/omg.gif[/img]
2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
Originally posted by blacksport: </font><blockquote>quote:</font><hr />Originally posted by AZ3.8Camaro: Those guys at clubgp seem to have the same opinion I have about it. On the fence.
Geeze, I dont like it when my car idles a couple ticks below 60. [img]graemlins/omg.gif[/img] </font>[/QUOTE]Yeah me either, but you only need like 12 psi at idle or so to avoid damage, so I don't lose sleep over it.
