Hey I found some heads of a 96-01 grand am 3.4L motor and want to make sure they will fit my f-body. Is this the same engine? I know the grand am is fwd but are the heads interchangable? thanks
wondering if...
wondering if...
94 3.4L firebird<br />BMR STB, BMR swaybars, H&R springs, Custom air intake, 160 temp stat, slp fan switch,aluminum 1 piece driveshaft, LCA reloc brackets and billet LCA\'s, Masitaly 18x8 wheels, Kumho Ecsta 245/40/18\'s , Custom exhaust, catco High flow cat, spohn panhard and custom upper rod, MSD blaster coils, MSD 6A, APC seats on the floor of my apartment and headers on the wayTags: None
Checkout Russell's post on putting the newer heads on the old 3.4. He did it, but it takes work. They fit... kinda [img]smile.gif[/img]
Ive seen it in person too.
[ September 24, 2003: Message edited by: Dominic ]</p>2002 5-spd NBM Camaro
Details: www.1lev6.com
Please make your topic description more descriptive per the advanced tech rules.
I had no idea what your post was about by looking at the title.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
