is my computer bad? - FirebirdV6.com/CamaroV6.com Message Board
is my computer bad?
  • is my computer bad?
    Friday at work i borrowed one of the mechanics Scanners. (i found out i have OBD2) so i was scanning my computer to see if i had any codes, Due to a possible abs problem.
    And it kept saying it cant communicate with my computer. Is that a sign that my PCM is bad? the couple mechanics said it was, but i wanted to ask some fbody pros.
    any help would be great
    95 black 3.8 camaro, Intake, Pacesetters, Flowmaster 80 series, accel plugs and wires, B&M shift kit (eh could be better), hopefully a highflow cat soon. and a bunch of appearance mods.
    Sounds like the fuse is blown. It's happened a couple times here. I believe it's the same fuse as the cigarette lighters. Check all your fuses to see if they're good.
    The likelyhood of the PCM being bad is pretty close to 0. There's a dozen other things that would break before that would.
    I'll get my manual out and see exactly which one you need to check.
    Matt
    1998 Mystic Teal Camaro M5
      Check the fuseblock on the inside of the door, fuse #11: CIGAR ACCY.
      Matt
        If your computer would be bad, - you wound not be able to start your car. Computer is the last thing that goes bad , and the first thing to blame when the useless mechanics don’t know what is wrong.
          yeah thats what i thought. . Ill check the fuses tomorrow morning and then see if i can use my dads scanner and see if it works.
          Im even thinking the mechanics are screwing with me. . because they told one of the other guys there that his pcm is messed up too and hes got an 00 or 02 civic.
            Have you configured the scanner to your car? If you haven't configured the scanner to the correct year and make then you would get that "cannot communicate with computer".
            ---94 Camaro-L32--- <br />\"Don\'t hate the playr, Hate tha GAME!!\" <a href=\"http://members.cox.net/jeanda_sd/SD_L32/SD300L32.jpg\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/SD300L32.jpg</a> <br /> <a href=\"http://members.cox.net/jeanda_sd/SD_L32/100_0022.JPG\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/100_0022.JPG</a> <a href=\"http://members.cox.net/jeanda_sd/SD_L32/L32flipmode.wmv\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/L32flipmode.wmv</a>
              What? Some of the early 95 model cars and trucks are labeled as OBDII but were actually still OBDI. I don't know if this has ever been confirmed but I've experienced this kind of issue before. My buddy has a 95 GMC Sonoma and it's supposed to be OBDII, but has never been able to be scanned on any kind of OBDII scanner. It's prolly just the old setup....OBDI with the OBDII interface.
              ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
                I agree with Matt, check the Cig fuse. but i also wanted to point out that you can have a computer problem and have everything else work including starting your car ;)
                2000 3.8 A4 Pewter Camaro
                  95 is the basterd year for gm. They used 16-pin OBD1 ports (normally 12 pin for obd1).
                  You can use a Obd1 12 pin on a Gm obd1 16 pin this is how.
                  http://shbox.com/1/xraycable.jpg
                  Or you just use a 16 pin OBD1 cable. If your using a real scanner like a Tech 2 then they should have this cable for you to use.
                  Also like stated above check that "11 fuse out [img]smile.gif[/img]
                  Now i thought the 3.8 in a 95 was for califorina and I thought they had to make it OBD2? If not then use the method i just showed you.
                  1999 Pontiac Trans Am M6 Far from stock.....
                    All 3.8s are OBD-II. Only the 3.4s were "OBD-II and a half".
                    Matt
                      jeanda I used the right cartridges for the scanner. It should have worked from what i understand. But im going to check out that 11 fuse. Why would the cigarette lighter/horn fuse cause the problem?
                        oh also the scanner is one of the Snap on ones. It was expensive as heck so im pretty sure its a good scanner haha.
                          Because that's where it gets its power from. ;)
                          Matt
                            on my scanner before you can scan you must configure "year", "make", &"Vin-#". Otherwise the scanner will not recognize what its scanning.
                            If yours doesnt ask for this information then I guess it might be something else then. -good luck [img]smile.gif[/img]
                              Yep this scanner asks for all that. . I forget which numbers it asks for im pretty sure the 8th, 3rd and i forgot the other ones.
