Alright, I got some P&P heads and lower intake, now my question is should I make the compression high by .1 or got with intense racing rocker arms? Which one would I make more power with? Keep in mind I will be spraying within the year.
rockers or compression??
the rockers would make more power and also how can you compare the two? it shouldn't cost over 50-75 bux to mill the heads...i milled mine .015 and it raised the comp about .1...its not much<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Originally posted by FireFighter:
it would retain the stock ratio of 1.6.www.turbov6camaro.com
1997 3800 Series II Camaro
