What cam companies, can and will produce a cam, for a 98 3.8,plus does anyone know how much a custom grind costs?
Cams??????????????
Cams??????????????
Msd wires,Summit coils,Cuctom CIA&longtubes 2.5inch w/side exit,Cam,Heads & Intake,30# injectors,reprogrammed computer,3400 edge Converter, 3.73\'s&LSD,Edlebrock torque arm, SLP LCA\'s,Jegs panhard bar,16 inch nittos Best ET 14.374 @94 <br />Best 60\' 1.91Tags: None
Please do a search, this topic is all over the board.
$299 from CompCams for your desired grind
Supersixmotorsports can also do a *regrind* on your current cam, but its not as good, but its far cheaper.2002 5-spd NBM Camaro
Details: www.1lev6.com
