I have a 2000 3.8 Camaro, with 107K miles on it, so I have decided to install a cam and rebuild the valve train, and maybe the whole engine. So here is what I got, and what I plan on doing...
My cam - 212/212 112LSA 109IC .520 Lift
I was planning to get the comp cam springs but should I get the 105 or the 130 lb? I am also entertaining other ideas for springs as well, if anyone wants to share thier opinions.
These are the other items I will be purchasing to go along with it since I am rebuilding my valve train.
Comp Cams "OE R Series" Hydraulic Roller Lifters
Comp Cams Valve spring Retainers Titanium
INTENSE™ High-Performance Pushrods Liteweight
Clevite 77® TriMetal™ Main Bearings
Clevite 77® TriMetal™ Rod Bearings
Gasket Set (havent decided, but GM is my first choice)
All the bolts for the heads, crank, pully ext.
I am also entertaining putting in forged pistons, piston rings, but I dont know which ones to get, again I could used some help? I know they make a few different kinds, doomed, flat, and one other.
I also thought about new rocker arms, but with this cam, I dont know if they would work.
Any opinion or help would be useful since I am going to start purchasing stuff this week. If I forgot any major part, or something let me know.
Thanks
Chris
[ September 28, 2003: Message edited by: twofaced ]
[ September 28, 2003: Message edited by: twofaced ]</p>
Thanks
Chris
