I've had this problem before. When the weather get's cold, as in 40 or below, my engine temp needle drops to zero or turns itself off. When this happens, a service engine soon light comes on and gives me a code saying that my coolant isn't getting hot enough. I have a 160* thermo and tuning from TSP for it. what could be the problem?
Engine Temp gauge won't work
I dont really know why your temp gauge would bottom out and i wanna say that it sounds like the 160* thermo isnt letting your coolant get hot enough but the gauge problem i would think is connected.
what is the code? cause the sensor might just be taking a dump.
[ November 29, 2005, 10:16 PM: Message edited by: BLLDOGG ]
TSP prob didn't delete the coolant thermostat code(138 i think?). Anyway, once that code is set to "no error reported", your problem will be solved.
g2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
g00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
I had a 160 at one time and my car ran at about 100 degrees in cold weather. I'd say its the thermo.2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
The code is the DTC warm-up code. The problem is, it's the same code I was having before the gauge went dead. The code happened during the summer as well. So, I know the code wouldn't kill the gauge, so could it be the engine temp sensor being dead, or something else?2001 Arctic White Firebird<br />More mods than I\'m allowed to list!
Keep in mind that the gauge is controlled by your temperature switch which is a single wire sensor in the cylinder head. Many people think that it runs off of the engince coolant temperature sensor which is incorrect.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Originally posted by viper98885:
Keep in mind that the gauge is controlled by your temperature switch which is a single wire sensor in the cylinder head. Many people think that it runs off of the engince coolant temperature sensor which is incorrect.Matt
1998 Mystic Teal Camaro M5
Originally posted by 98Camaro3.8:
Do you have any more information on this? Is it only 3.4s, or 3.8s also? I've never heard of this and cannot find any info to support it. Where is this sensor at?
The older 3.4L V6 uses one sensor in the cyliner head that is a single wire and then a seperate ECT with two wires.
The new 3.8's have the two sensors combined into a 3-prong setup which is located on the front of the intake manifold.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
The problem is the way the car reads the temperature. If it is too low for to long, it just drops out the reading. I had a 160* and it happened all the time. I would clear the code and in about 20 minutes it would come back (it might even have been the second cycle, some codes have to go twice before they regester). I called Hypertech and they said this was a problem with late model 3.8L V6's. I switched to the 180* and the problem went away.
Then I got HPTuners, deleted the code (138 I think), put the 160* back, no more problems. There is nothing wrong with the thermostate, no ones car was running at 100*, and the gausge is doing what it is suppose to. Either delete the code or get a 180*.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
