Well i had put off the iron head for a while...then after a few days i put it back and started...the engine was SCREAMING!! What the hell happend?? Could some thing had fall down in the cylinders?? PLEASE HELP!!
HELP!!
Well i don´t know much about it? But now my engine is whistling or rather screaming when i start it. It´s not the RPM that is the noise? It´s somethin else that i can´t describe=( Could it be be something with the throttle body? When i take off the air filter thing (what´s it called) the same noise is still there?? Has´nt anybody had the same problem?
From the Advanced Tech: Rules and guidlines post..
Rules for Advanced Tech:
3. Make your topics descriptive! Try to give a little more info about what your question relates to. Even post specs in the topic as well. Just make it descriptive!
So next time, try to use a more detailed topic name. Thank you.
- KeithKeith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
when you pulled the head off, did you replace the head gasket? you should ALWAYS replace the head gasket after pulling the head off, as well as any other gaksets that got removed in the process of taking the head off -- that were ripped or damaged and do not look in good condition. DO NOT USE SILICONE ON THE HEAD either..this is a baaaaad idea.
anyway, hope this helps somewhat..
-R
hybrid - \'\'hI-br&d - The offspring of a cross between species.
Co-Founder West Coast F-Bodies
West Coast F-Bodies Car Club - WCFB Message Board
I'm not quite sure I understand what your saying either. The noise could me many things. Does it actually sound as if it's internal or like and vacuum leak?94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
FOR EVERYONE THAT DOESNT UNDERSTAND THIS GUY:
<blockquote>quote:</font><hr>Originally posted by -=)FirrmaN(=-:
Well i had put off the iron head for a while...then after a few days i put it back and started...the engine was SCREAMING!! What the hell happend?? Could some thing had fall down in the cylinders?? PLEASE HELP!!<hr></blockquote>
Translation:
Well I took one of the heads off for a while, and after a few days put it back on and started the car... the engine started making a noise like it was SCREAMING!! What the hell happened??
Could something have fallen down inside the cylinders while the head was off? PLEASE HELP ME!!
From what I have been told by several engine builders, you should NEVER use silicone gasket maker for a head gasket!
this is just what i have been told. as for the rest, if you used silicone anywhere else, like on the intake, you might have accidentally missed something and left a hole, where the engine is sucking air in. if you used silicone gasket maker on the heads, then pull the head back off, and pay for the gasket. THE HEAD GASKETS HAVE METAL RINGS THAT RESIST THE EXPLOSIONS THAT HAPPEN IN THE CYLINDERS!!
at least im sure thats what those are for. think about it..things get really hot down there, the silicone would burn away after a little while...
-R
correct, silicone RTV is not to be used to seal cyl heads. use only cyl head gaskets designed for this purpose.
one comment about sealant for the intake manifold, make sure it's O2 sensor safe, else you'll be buying O2S's every month or so.
assessment of problem, suggestions: probably small intake leak. get a stethoscope from AZ and listen to where it's coming from. how's the idle? how fast and how steady? does the noise go away at high rpm's? use stethoscope to locate noise and go from there.ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
