The compcams camshaft @ Grandprixstore.com is a Xtreme Energy Hydraulic Roller Camshaft...
Being it is hydraulric roller, does that mean it requires roller rockers?
I know it needs stiffer valve springs, the lift is on up there.
I have confidence in saying this camshaft with STOCK HEADS will provide a minimum of +25bhp for us, I just need some valvetrain information from you guys [img]smile.gif[/img] .
They hydraulic roller part is refering to the lifter... We have hydraulic roller lifters so you're alright.
The lifters are the things that make contact to the cam. The pushrods sit on top of the lifters. The cam lobe pushes up the lifter.. the lifter pushes the pushrod, the pushrod hits the rocker, the rocker tips and the valve opens. [img]smile.gif[/img]
<blockquote>quote:</font><hr>Originally posted by cb1101: just wondering..will the comp cam fromgrandprix fit in a 3.4 bird or no?<hr></blockquote>
No, however compcams makes a cam, and tiago got/could have got a custom one from NRT, if I remember correctly.
Chance<br />1999 Grand Prix GTP<br />*stock*<br />1993 Camaro<br />Custom intercooled turbo, BMR suspension, huge stereo, appearance mods......<br />and now most is FOR SALE! :p)
Being that Tiago got the Nu-Tek package from James Montigny -- he didnt take the camshaft. he just got the heads/intake.
the camshaft is pretty mild. i mean its good for some gains but without the NRT heads it probably wont do much, its really custom ground to match their airflow profile.
<blockquote>quote:</font><hr>Originally posted by TheCardinal: Being it is hydraulric roller, does that mean it requires roller rockers?<hr></blockquote>
you should use roller rockers.
ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
