So i know when i change my rocker arm ratio it esentally changes my cam profile and that is how i make better power.
Question#1- does anyone have the slp rocker arm ratio kit, is it worth the money? And does it help you engine rev higher.
Question#2-If i get an after market cam, like the comp cam, will that make the lift and duration to high?
2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
