I understand "All 60* rockers are nothing more than SBC rockers with modified balls,Where do I get the "modified balls" or the "narrow body rocker" (can I find these at eBay???).
The modified balls are already on my engine, they differ from the SBC ball only in the hole that is drilled in them..!!!??? ,So if i buy a SBC roller tip rocker they will work just by using my stock rocker ball.???
Can i pick up a cheap set of SBC rockers at eBay and use the stock 10mm rocker balls...????????????????????????????????????????
"Cheaper than the Comp Cams Magnum rockers and they seem to work as well"
like... http://cgi.ebay.com/ebaymotors/SB-Ch...19083640QQrdZ1
I know comp cams # COMP-RP1414.12 from www.ftpp.net are designed for 3.4……but the sbc are cheap..! please help……..
[ December 07, 2005, 02:08 AM: Message edited by: monge_3.4 ]
