alotta people say that puttin in the 160 thermo will trigger SES lights and the way to fix that is tune the pcm... how? send it out or buy tuning software or what? also, if you get a manual fan switch, do you just let those bad boys run as long as the car is on, or only once its hit 160 or when? and one last thing here... the operating temp means taht at that temp all the parts have correctly expanded to fill in all the tiny little gaps that can cause emissions and the engine will run the best. if you change the operating temp to 160, wouldnt that be harder on the engine (i.e. breaks down sooner)? just some thoughts...
160* thermo
This topic is closed.
in talking to one of my friends he thinks its because the engine isnt warming up quick enough...not that its not reaching a high enough operating temp. But yeah you need to get the code turned off via tuning. The thing is without tuning the only time you'll run at 160 is in cooler temps and/or steady state driving at speed. If your in stop and go traffic just remember that your stock fan settings are still in there so they wont turn on till over 210*.00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
Originally posted by Camaro Dom:
i'm thinkin about installing a manual fan switch, do i just let that run all the time, or only in stop-and-go?
Moving to General Tech.Matt
1998 Mystic Teal Camaro M5
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
