For any work on your car, you need to at least get a Haynes manual. That'll tell you step by step how to do it.
No, you shouldn't have to remove the intake manifold, and usually not the injectors. But I'm not a 3.4 expert, so I can't help you with any of the little tips for that motor.
and yes you have to pull the injectors and the upper intake to get to the valve covers its a pian in the asss.
Also be careful with the t-fitting vacuum line on the front of the intake manifold its kind of fragile.
I did it to my 3.4L at like 2am with a AA maglite as my light source.
1st time I ever did it on a 3.4L and it came out fine, car is still on the road, running fine 55k later. I did snap an intake manifold bolt, I just rigged one with a bolt form home depot and some washers.
Originally posted by 98Camaro3.8: </font><blockquote>quote:</font><hr />Originally posted by shenanigans:
Really? Wow, that is a pain the ***. Glad my 3.8's easy to work on. Can't count how many times I've had the valve covers off. [img]tongue.gif[/img] </font>[/QUOTE]That bolt behind the valve cover on the passenger side is a *****.. how did you do it?!
