I know this has been discussed to death but I couldn't find an answer in the search. I'm swapping in a new engine and need to replace my current injectors (have 115K miles on them). Stock replacements are freaking $60 a pop from gmpartsdirect whereas I can get 8 new Accel 21 Lb injectors for $238 from summit (8 injectors = 6 plus two spares just in case [img]smile.gif[/img] or I could get 8 Accel 24 Lb Injectors for the same $238. Which should I get? Oh, and I will have an Autotap and a Mini-AFC 1.0 by the time the injectors are here so I could tune the 24 lb'rs, but would the 21 lb'rs be better??
Accel 21 Lb Injectors or 24 Lb for stock heads/cam??
C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail BirdsTags: None
24 lb'ers... i ran them and they worked great
I'd try to find a used set though or perhaps some LT1 or LS1 stock injectors.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Yea, which makes it hard to tune at higher levels.
Accells are pintle style. A 24lber though shouldn't be a problem.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
The mini-afc is supposed to be able to tune from 10% to 255% on the fuel curve and with the autotap I should be able to adjust it to a very acceptable base and WOT setting right? I don't want to have a problem i cant fix. Also, the mini-afc does not change timing but i assume this is not a problem.C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail Birds
would you just be able to get some used l67 36lb/hr (i think) injectors, then lean it out with your afc? they're always for sale on www.clubgp.com. i just dunno if the afc/maft would be able to lean it out enough???
--matt
Try $100 for a set of 8 new 25 lb/hr's:
http://www.slponline.com/view_produc...RTNUMBER=23051
Yeah, it's SLP ... but hey, it's SLP.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
i run the 24 #'s off of an LT1. they work fine.
stock ones are 22#'s.. why go to 21's?96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
