I plan on going FI soon.. I was wondering how hard it would be to get an L67 motor in my car with an aussie M90 on there.. Would I need a GTP PCM? Would it bolt in normally? Would my tranny mount up? Thanks
L67 engine swap
your tranny and motor mounts will work, but the gtp ecm will have the wrong gear ratios & shift points
and aside from snout length all m90s should have the same external dimenionsWolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
there should be tuners programs that can take care of the gear ratio issues. best thing tot do is see if you cain get the aussie pcm w/harness. The three most difficult things to get for this swap are: aussie supercharger, aussie pcm, aussie harness. Other than that it should be cake ;)1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
