my question is.........i have this pinkish wire coming out of the fuse box inside my car. i looked in my owners manual and it said it was for an after market ignition. so. is this something my car came with from the factory and does anyone else have this same wire?
ignition
This topic is closed.
There's a pink wire that comes out of fuse #9. It's got power for BCM, lights, and instrument cluster. In the owner's manual, it says it also has an "auxiliary accesory wire." That's for what you may install later, like a wideband oxygen sensor or something.
Moving to general tech.Matt
1998 Mystic Teal Camaro M5
