Has anyone else heard this? - FirebirdV6.com/CamaroV6.com Message Board
  • Has anyone else heard this?
    The guy at Autozone said he couldn't pull my codes because he didn't have the equipment to do it. I said "you've got one on the shelf, what's the problem" and he said that the 95's have a OBD1(or whatever) computer and an OBD2 connector.
    I researched this a little and the OBD2 standard didn't get enforced until 96, when F-bodies went 3.8. So, apparently, if you have a 94/95 3.4 you can't pull the codes?
    I personally think it's a load of crap. How could GM be so stoopid? I've never tried myself to pull the codes, and everyone with an F body I know is a 3.8 and they just go to AZ to find their problem.
    If the computer is indeed an OBD1 computer, couldn't you just short A and B (or 1 and 2 or whatever) and get the blinking SES light? Or is that not kosher anymore?
    I'm confused. Help!
    -Brian
    P.S. The owner of my local AZ should be bound, gagged and pelted with crankshafts. Just thought you should know.
    Maroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
    Yea, during the transition period there were some OBD-I cars with OBD-II type connectors.
    I forget what was done to read the codes.
      does anyone know when? cuz I been praying my 94 was an obd1, I'll yank the connector if I cna do what my 85 did to get "jump" the 2 wires and get morse code flashing.
        There is a OBD1 reader also. I know that 94s for sure have a way to read it.
          The obd1 reader works on the 94?
            My '94 lesabre had OBDI computer but a OBDII connector. Some models had this, some didn't. I used to have an OBDI autoxray scanner and bought the OBDII connector for it. It worked well, but I traded it out for a OBDII version, since I sold the car.
            DEE
            1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
              http://www.autocheckup.com has some pretty good prices on their scanners and you can get a OBD-I and an adapter to fit the OBD-I computers w/ OBD-II 16 pin connectors I believe.
              Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
                w I ca check my computerfor te cheap price of $190 not including shpping and handling?
