was looking at getting the stage 2+ powerpak kit from supersixmotorsports.com, was wanting to know if I should put new pistons and all in as well to make things more stable. My 96 3.8 has 206k on it is why I ask.
heads and intake
with that many miles, you minds just rebuild the whole thing and make it all fresh. You can get by without going the low end, but why not if you have it all apart already anyways with all those miles
ok....i am the person who posted the sticky on the head research for the 3.8. if ur looking for a specific kind of head (there are about 3 or 4 different main head ports that our vendors offer)then i suggest you READ IT. Not really paying attention to all the details but just to see which head flows the best, which has most velocity and which is most efficient.
With ur car having 206k miles on it I also suggest that you do a complete engine rebuild. At that mileage your piston rings are probably shot, the cylinder walls need to be honed and bored, ull need oversized pistons with connecting rods. Its up to you whether you wanna swap out the crankshaft or not. But once you get down that far ull be messin with the bearings and everything. The only thing you will probably not need to replace is the block itself.
The most economical and cheapest way to go about it is to use the 4 grand ull need for a 3.8 rebuild and put it towards an LS1 swap , which would probably cost you less anyways
But assuming u wanna stay with the 3.8 then use the above information as a guideline.SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 week ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
