APP vs throttle postion - FirebirdV6.com/CamaroV6.com Message Board
  • APP vs throttle postion
    so i autotapped tonight, and my accelerator pedal position shows 100%, while my throttle never goes above 96%. what's the deal? SHOULD i tweak the throttle so it opens to 100%, or is this normal?
    --matt
    normal.
    To be sure, just eyeball the TB blade. If it opens TOO far it will set a DTC.
      should i tweak it a little closer to 100% ya think? thanks
      --matt
        physically check the TB. if its opening 100% then its opening 100%.
        The readings you are seeing are not exact. The actual position of the TB is.
        If it opens too far you will have issues.
          Normal, just as Magnus stated.
          This page shows a little trick to get the LS1 throttle blade closer to 100% open
          http://www.installuniversity.com/ins..._bump_stop.htm
          ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
