I rebuilt and reinsalled the Upper Valvetrain Inc. Heads rockers, lifters, and new valve seals. And when i start her up for the first time. She has a Misfire and Flashing SeS light. I checked all plugs wires and replaced the plugs but its still there any help would be appreciated.
Help me out with a misfire pro
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
You need a scan tool bro -- it will tell you which cylinder, and then you can specifically check the plug, wire, and coil on that cyl.
Got the wires on the right plugs? Got tons of knock? (but I doubt that would make it flash)<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
Originally posted by RallyRed 98:
flashing SES means that your emissions are 1.5 times the acceptable level. be sure to check upstream of the plugs and wires too, like your coil packs, ICM, etc.
A flashing SES light signifies a misfire. Misfires screw up emissions but not all causes of increased emissions are misfires.
If your sure you have a misfire and dont' want to spend the extra coin on a scanner, buy a sparkplug tester and a ohm meter. Its basically a spark plug with clip welded onto it. Use the ohm meter to check the resistence in the wires. Make sure they fall within the specs listed in a service manual. Then check each spark plug wire with the spark plug tester. Have a budy crank over the engine and watch for a spark. If your not getting a spark on one cylinder, you narrowed it down to either the coil or the Ignition control module. I would switch locations with the non firing coil with one that works. If the same coil is bad in a different location than the coil is bad. If the non firing coil fires in a different location, then the ICM is bad. Good luck69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
Sounds like a bad coil to me. But your initial focus should be plugs, wires, and coils...Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
http://seppo.hopto.org/
A flashing ses light means that you have a misfire so bad that it is going to damage the catalytic converter...and that's all it means. The ohm meter check on the plug wires only works if the cable is physically broken inside the insulation.2005 Magnum
