i was going to bore my block .030", but with a huge cam, will i benefit more from boring .040" over? I was reading an old post by oil pan, and he said that it is safe, can anyone tell me for sure if it is safe? what about this bore with say 50-75 shot of nitrous? What will my compression be like after?
Boring a 3.4 *****.040"**** safe?
the ammount of volume you are going to gain by going .040" over isnt much, personally i wouldnt bother comprimising my block for the 2 or so cubes...
your CR will be affected by the pistons you choose to place in the motor-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
your CR will be affected by the pistons you choose to place in the motor- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
It is safe but not worth it.
If you bore it .040'' and some thing hapens (realy think about it, with a nitrous engine) and you have to bore it again you will be boring to .050 or .045'' That's over 1mm off each wall. That would push it on a nitrous engine.
I have seen 2.8L-3.1L blocks have been bored up to .080''-.090'' on an all motor race car, no power adder. I don't think they were built to last a long time.
The cylinder walls on the new hemi engines are done by some new casting methoid and the walls are .100'' to .110'' thick that is a little over 2.5mm.
3.4L block walls are 4.5mm thick.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
Ok, guess i'll stick to .030" (my original plan and some speedpro pistons). Thanks for all the advice, i really respect all of your input. One last question, with my rebuild, i was thinking will putting new pistons(not forged)in really be that beneficial, (it will cost me!) or should i just leave it alone. btw my car has 82,000 miles on the clock.
will a forged piston yeild more power over a cast or hypersplosive piston?, no, however they can take more heat and not break
and i have no idea where this "a large piston will tame a cam" thought is coming from-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
I thought it was more compression helped to tame bigger cams not larger diameter pistons. When I was looking at cams the manufactures always wanted you to have more compression with the more radical cams.1994 Chevrolet Camaro 3.4L A4 (160hp 200tq)<br />2006 Nissan 350Z 3.5L M6 (300hp 260tq)
One of the main benefits of the forged aluminum pistons is the fact that the are lightweight and have a low "bob" weight (weight put on the crank at the top and bottom of the stroke). This will allow the engine to rev faster. The Ross flat-top pistons will offer a 10.0:1 compression ratio over the stock 9.0:1 compression. I have 2 sets of Ross flat-top pistons here that I am giving away at a helluva deal if anyone is interested. I have one set that is standard bore and one that is .020 over.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
