I have a 97 Firebird and i am trying to put an Air/Fuel gauge in my car. and I am looking for the combined o2 signal wire that goes into the pcm. Does anyone know where this wire is? Thanks
Air/Fuel Gauge help
Air/Fuel Gauge help
1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQTags: None
I tapped into the 02 sensor itself. I don't think there is a combined wire. I believe they all feed into the pcm separatley.
Get under the car and find the 02 sensor on the driver side cylinder bank. The purple wire coming out of the o2 sensor is the one you want.
Fuse that together with the aprropriate wire on your gauge.
Thats how i did it anyways.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
Does anyone else have any advice for me on this?1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQ
i ran mine to the o2 sensor on the cat...and brought it through the shifter hole. There is no combined wire that i am aware of...the sigals should be separated even on the ECU1998 Chevrolet Camaro L36 M5<br />1982 Toyota Celica Supra 7MGTE project car - FOR SALE<br /><br />\"I find the most sensual part of the woman is the boobies.\" - Zap Brannigan
