ok, The SES light is on in my car. I think that it is the o2 sensor that is after the cat. But I don't want to spend the $60 just to get the car scanned if that is it. So I was wondering if I could put a resistor in the sensor to make it "think" it is running with a stock cat. This way I can spend ~$5 to see if I am right instead of $60. anyone ever done this? TIA
o2 sensor OHM resistance??
1996 Y87 Camaro, 175.0 rwhp, 211.6 rwtq.....1/4 15.500@88.54 <----- Needs work!!<br />-CAI, Custom bent S-Pipe, LS1 I-Pipe, Flowmaster 80 series, !MAF, manual fan switch, relocated trunk pop switch, 180 degree t-stat, More to come!<br /> <a href=\"http://camaro.wbisolutions.com\" target=\"_blank\">http://camaro.wbisolutions.com</a> <p>WANTED!!! Naked and handcuffed!Tags: None
If i am not mistaken, the O2 sensor reacts with the emissions to PRODUCE voltage. Its not like the IAT sensor at all. You could get an O2 simulator, but it probably costs the same. Someone should make an adjustable 02 sensor, so you can make your car run lean or rich with it.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
cool thanks for the info!1996 Y87 Camaro, 175.0 rwhp, 211.6 rwtq.....1/4 15.500@88.54 <----- Needs work!!<br />-CAI, Custom bent S-Pipe, LS1 I-Pipe, Flowmaster 80 series, !MAF, manual fan switch, relocated trunk pop switch, 180 degree t-stat, More to come!<br /> <a href=\"http://camaro.wbisolutions.com\" target=\"_blank\">http://camaro.wbisolutions.com</a> <p>WANTED!!! Naked and handcuffed!
DO NOT check resistance of O2 sensor. you may check resistance of the heating element for the sensor, but NOT THE SIGNAL WIRE.
check for voltage produced. engine running, hot, should vary quickly between about .2-.8 v.AC
you can also test with a propane torch and a voltmeter.ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 week ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
