I brought car to shop after redoing the heads and all valvetrain and i couldnt solve a misfire problem. Well turned out to be a injector not functioning. then they ran further tests to fin that Cly. 2 has no compression and the othere Cly. have very odd random spratic amounts of compression. They want $1500 to fix i think its the heads what do yall think.
Took car to shop bad news
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
i dont really know that much..but do you mean the other cylinders have incorrect compression or their compression changes every cycle?..if the compression is that crazy and changes that much could it possibly be some f*cked up computer issue?<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Man ive had the same prob turns out my vavle was stuck in the guide plate and trick the computer to think all the cylinders were missfiring. There charging me 1200 for all the gasket needed and remanufactured heads1999 Firebird 3.8 Chamelon<br /><br />MagnaFlow Catback<br /><br />Devon
Originally posted by 1DangerousV6:
if the compression is that crazy and changes that much could it possibly be some f*cked up computer issue?Matt
1998 Mystic Teal Camaro M5
Originally posted by 98Camaro3.8:
</font><blockquote>quote:</font><hr />Originally posted by 1DangerousV6:
</font><blockquote>quote:</font><hr />Originally posted by 98Camaro3.8:
I got a ported set of heads in my garage im taking in to get new valves and cleanup work and valve job for $150 bucks then i got the guy who built my 70 chevelle to intall heads and **** for 500 bucks i cant work on it anymore<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
Unless it was the mechanic's computer (compression testers are mechanical BTW), the PCM on slacker's car (and everyone else's on this site) does NOT affect the compression test results, period!<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
i almost bet the valves weren't sealing on the seats. A cheap valve job will do that. Lap the valves in to make sure they seat all the way around so you KNOW they wont leak.<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
If you need a set of heads, click here. http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
Ed hooks up the GP community with alot of aftermarket parts. He just so happened to post up some low mile L36 parts.1999 Grand Prix GT<br /><br /><a href=\"http://www.fishsgt.com\" target=\"_blank\">www.fishsgt.com</a><br /><br />Best ET: 14.94@91.25MPH with a 2.2 60\"
