Does anyone out there know a supplier for an adjustable fuel pressure regulator? I know RKsport used to, but I recently checked and its gone from their website. Also tried 3800performance.com. Don't know too many performance suppliers for L36's. Help me out please. Thank You.
John- 1997 RS 3.8 30th anniv. edition.
My 3800 II equipped camaro has an adjustable fuel press regulator installed from the factory. On the back of the regulator pot, there is a T-20 security torx screw. Turn that and it will adjust fuel press.
1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
I just removed the regulator vacuum hose from the
side. Gets 55psi throughout the entire RPM range.
You might need programming for this, but give it a chance. See if it works ok.
Thank you for your responses. I will b sure to try those. The reason I need one,Wicked, is because I would like to put a small N2O system on, and along with colder plugs (NGK Tr6's) I will need a small amount more fuel to reduce the risk of pre-ignition.
