Someone please explain to me how to replace my TPS and how hard is it ?
How do i replace a TPS ??
It should be fairly easy. First you disconnect the electrical connector from the TPS. Next, you remove the torx drivve bolts from the TPS and remove the TPS from the throttle body. When reinstalling the TPS make sure to align the socket locating tangs on the TPS with the throttle shaft in the throttle body. Hope this helps.2000 Camaro 3.8 v6 M5
Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
"Right, mmkay...I'm gonna have to ask you to put the new cover sheet on the TPS reports..that'd be great.."
Sorry, I HAD to. [img]smile.gif[/img]2002 NBM Firehawk #312 | <a href=\"http://hawk.visionsconnect.com\" target=\"_blank\">hawk.visionsconnect.com</a>
