Saturday me an a couple freinds are putting my cam in. I know its suppose to be 500 miles before its fully broken in but can I just leave it idling the rest of the night Saturday and all Sunday? Or does any one know how long i need to leave it idling?
Break In Questions
Break In Questions
2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>Tags: None
For the most part, there's no real need to break it in. Since we've got hydraulic roller lifters, there's not a big break in procedure. Let it idle for a while to check for leaks, etc, then drive around lightly to check everything out. You'll also want to change the oil after 50 or 100 miles. I was real easy on it for the first 500 miles or so. Started out not taking it above 2000, then slowly worked my way up to redline.
Here's a thread I posted while I was doing my heads/cam: http://www.camarov6.com/ubb/ultimate...6;t=002721;p=1Matt
1998 Mystic Teal Camaro M5
Originally posted by pgriffith:
Install the cam then drive it like you stole it. You dont have to break in hydraulic roller cams like you do the flat tappet and solid cams. Install it and drive it, no break in.1998 Chevrolet Camaro L36 M5<br />1982 Toyota Celica Supra 7MGTE project car - FOR SALE<br /><br />\"I find the most sensual part of the woman is the boobies.\" - Zap Brannigan
I didnt think I could stand driving it a couple hundred miles with that cam and not get on it once! LOL2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
Did you read the literature that came with the cam? It should tell you the cams break in procedures or what they recommend. Most cam companys have been in the business long enough to know how they're cams react to different break-in methods. I know with rollers, there's not much of a break in period, but you should check with the company, you never know. Better safe than sorry. Good luck!1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2
Originally posted by tdz16:
Did you read the literature that came with the cam? It should tell you the cams break in procedures or what they recommend. Most cam companys have been in the business long enough to know how they're cams react to different break-in methods. I know with rollers, there's not much of a break in period, but you should check with the company, you never know. Better safe than sorry. Good luck!<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Roller cam no break in.
Tune it up, it won't run right most likely after the bigger cam is installed.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
