2.8 Crank - FirebirdV6.com/CamaroV6.com Message Board
2.8 Crank
  • 2.8 Crank
    Is there any difference between the 2.8 crank and the 3.4 crank?
    -Travis<br /><br />95 Camaro 3.4 M5<br />Pacesetter Coated Headers<br />Catco Cat, <br />Dynomax muffler with custom piping<br />Custom Cold Air Intake<br />B&M Ripper Shifter
    stroke of a 2.8L = 76.0 mm
    stroke of a 3.4L = 84.0 mm
    -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
      In the later 2.8 cranks and 3.4 cranks that's about it.
        so to put a2.8 crank in a 3.4 would suck? lol
          oh, btw oil pan, with the 2.8 on the 3.4, if it didnt clear the coil packs, they could be relocated right?
            2.8 intake on the 3.4, sorry
              if you put a 2.8 crank in a 3.4 get some coustom pistons for the 3.4 bore and the 2.8 rods you could make a nice high rpm screamer!
              83 firebird 2.8 carbed stock for now<br />84 type10 cavalier hatch back 3100 5spd swap 14.96@91 in the 1/4<br />14.30 on slicks<br />76 cutlass, project car
                Well you can splice wires and relocate the coil packs, it might be a PITA. I bet you can do it just figure out where the coils will go.
                You would need pistons with a 3.4L bore but with a 2.8L piston pin hight.
                They will be massive and should be forged or they will just come apart with high rpm's.
                  early 2.8 cranks had small jounral mains
                  2013 Ram 1500 Big Horn
                  94 comero 3.4
                    so do you think it would be worth the trouble to go with a 2.8 crank/commecting rods
                      I dont think there would be any gains.
                      $Ryan$<br />95 3400 Teal Green FireBird M5<br />Mods: see link <a href=\"http://lowrider.cardomain.com/id/mystical420\" target=\"_blank\">http://lowrider.cardomain.com/id/mystical420</a> <br />1986 Gold Mazda B2000 ROTIP :)<br />*New*74 Moded 350 Chevy Pickup
                        maybe in a high revving solid roller cam setup it would be worth it
                          sounds like too much trouble, swap the motor if you want more power, or a high rpm screamer.
                          255/50R16 Tires, Pioneer Deck, Pioneer 4 Way speakers, PPI Amps, JL subs, Spec Stage 3 Clutch, Optima Yellow Top
                            ya
                              I've heard of some people swapping the 2.8 for a 3.8, but those are just rumors ;)
                              94 comero 3.4
