timing adjustment - FirebirdV6.com/CamaroV6.com Message Board
timing adjustment
  • timing adjustment
    as you can see i run nitrous..i'd like to be able to run it whenever i please..i dont really "street race" but every once in a long while i'll gun it quick just to see who's got the faster car if i think its a worthy enough competitor..so anyways..im gonna be running a 100 shot direct port..id like to retard the timing 2* and just run 92+ octane fuel..my questions are these...when im not running nitrous is retarding the stock timing 2* going to be harmful at all?..will the PCM make any of its own recalculations for this?..how much will i really notice a loss in performance?..and finally..should i actually just leave the timing stock if using 92+ octane fuel and NGK TR6 plugs?..thanks in advance!
    Retarding the timing 2° while N/A will not do anything except make a little less power. But you have HP Tuners, so why not just make an N/A tune and a seperate nitrous tune, then when you want to juice it just use the nitrous tune.
    Matt
    1998 Mystic Teal Camaro M5
      hmmmm..but how do you have both files?..an n/a file and a nitrous file..and then how does the car choose between the two?
        hes saying reload a new file knowing it only takes 27-32 seconds.
        00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
          ohhhhh...got ya..i was confused because i know the PCM will choose back and forth between high and low octane tables..i dont really want to do that because i just want the car to be ready to go if im driving along...so i guess it comes down to leaving the timing stock..or retarding it 2* ..how much of a power loss do you think 2* would take?..would it even be noticeable?..i appreciate the help
            yah in your case i would just safely tune it all the time.
              2* retard will not affect your eninge other then a small performance decrease. But then again 2* advance should be safe also when using nitrous. I would leave timing stock.
                yeah..i may just try a 2* retard at first..cuz when im driving im just..driving..doing the limit..maybe 70 at times..and if i hit the juice its gonna be [img]graemlins/wavey.gif[/img] anyway lol ..i'll log some runs both ways but i guess i'll play it safe first..thanks guys!
                  I used stock timing when I sprayed the 125 shot and nothing happened.. I have had the juice for 2years now and have put 65 bottles trough a stock motor.. I used stock timing and stock A/F on the spray and on motor I advanced 4 degrees and leaned out 2%.. That was with a Maft+ tuner..I also have a walbro 255 pump so it is rich as hell..
                  Jeff ..
                  1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
                  2002 WS6 T/A.. Bolt ins..448rwhp
                  2009 G8 GT.. Vararam intake, GXP axleback
                  1998 Corvette.. Vararam intake, Ti axleback
                  http://www.fquick.com/slow-v6
