curious as to whether this engine uses the same engine mounts and bell housing as a 2.8 found in the fiero. can someone enlighten me? it looks like a good option for a low weight, high power option for the fiero.
60* 3.6 dohc
60* 3.6 dohc
2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhardTags: None
3.6L DOHC was introduced in 2004.
http://60degreev6.com/modules.php?op...rtid=17&page=1
Check the forum on that site, I'm sure someone has asked the same question.Matt
1998 Mystic Teal Camaro M5
its an all aluminum block and head v6 that is in caddy's and a buick or two. it puts out 250ish hp stock and weighs almost nothing. i figure a turbo one of them would kick *** in a fiero. thanks for the link 98camaro3.8 i will try my luck their.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
60degreev6.com is good.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
