the battery for the laptop finally came so i took the car for a spin to log a run..it was NA..just me punching it up to about 60mph..i noticed everything working fine except the IAT sensor..it doesnt move AT ALL..just sits at -38*..whats the deal with at??..should i replace the sensor?..also..at one point in the run i got as much as 3* of knock..is that bad?..i dont know whats normal..could it be from the lack of IAT sensor?..thanks! [img]smile.gif[/img]
Logged 1st run :) ...but have 1st issue :(
<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Tags: None
AIT stands for air intake temp sensor. if its 38 below up there in new york then why would it get warmer in the 1-2 feet of your intake before it hits your sensor95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
Do you have an SLP temp module, or an IAT resistor or anything? Intense could have also edited that value from the file you ordered from them awhile back. I know when I've autotap'd my car in the past it will read a straight 41* due to the temperature module in my car. Sounds like maybe you have something similar installed.AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
no its nice up here..like 40* ..but the IAT sensor doesnt move at all..its like its not even hooked up..i had a problem with it a while ago..i pulled the wires out the back by accident when i was working on the car..i hooked the wires back up and everything but didnt realize there was still a problem..i think that might be causing it..i'll just get a new pig tail and sensor for like $20 and see if that takes care of it..its pretty cheap and that will eliminate it being the sensor..but would that cause the 3* of knock i saw?..or is that normal?..thanks guys!<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
well if your sensor is telling the computer its neg 38 degrees its probably adding a good bit of timing that could be your cause.00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
You should be getting an SES light from that IAT. Anything below -29° will set a code.
The IAT sensor has so little control over timing, I doubt that's it. It only retards the timing like a couple degrees when it's hot out.
Can you post the whole log so we can see it?Matt
1998 Mystic Teal Camaro M5
Just a thought. Did you see if there were any trouble codes displayed? If you have a lower temp stat, you may be throwing a thermostat code which would cause your temp gauge not to work.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
yup..i've been shutting it off so much lately i just set it to not turn the light on..i can post a log tomorrow..my gf is using the laptop for school right now..id like to post one anyway just to see what all you tuners think of the #s..but basically everything is working fine..injectors, o2s, MAF, etc..except the IAT sits still at -38 (which is the lowest on that gauge)..and of course the things this might possibly be effecting..i just bought a new sensor and have the pig tail connector on the way..im thinkin that should do it..i'll post a log tomorrow and then one after i fix the sensor [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Get a new IAT sensor and be done with it.. It only costs $10 max2000 Firebird.. Whisper lid, Custom exhaust, FRA mod, MSD Coil packs, MSD wires, TCI 3000 stall verter, TSP mail order tune. No times as of yet waiting for the track to open
when a sensor reads -38,-39, or like -40 it means there's an open in the circuit. The PCM defaults to that reading. Replace the sensor and you should be good.
~Tom1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2
hmmmmmm..thanks..i'll have to do some more and figure it out..most of my time's been spent on the new nitrous system<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
it is the cause of the knock because the pcm is adding like 12 degrees of spark at that temp.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
yup..i replaced the IAT sensor and harness and took the same run..the IAT and everything looked normal and knock was at 0 pretty much the whole time except for at one point when i saw .2 ..so..thats that..thanks guys [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
