Logged 1st run :) ...but have 1st issue :( - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    hmmmm...thanks!...i'll have to check that one out..when flooring our cars up to about 60mph like this..what are some normal spark advance numbers??..i forget what mine were..but i'll have to check that out too
    • #17
      Originally posted by 98Camaro3.8:
      You should be getting an SES light from that IAT. Anything below -29° will set a code.
      The IAT sensor has so little control over timing, I doubt that's it. It only retards the timing like a couple degrees when it's hot out.
      Can you post the whole log so we can see it?
      Anything below -29*F sets a code? I doubt it. Not on Canadian cars anyways. Its nearly always colder than that during the winter here.
      1997 Chevrolet Camaro<br />5 Speed STD 3.8L V6<br />Mods: !cat, Cherry Bomb Super Turbo muffler<br />15.9@86mph 2.353 60\'@1600ft<br />400,000km
      • #18
        Originally posted by Iwantafbodyagain:
        </font><blockquote>quote:</font><hr />Originally posted by 98Camaro3.8:
        Anything below -29*F sets a code? I doubt it. Not on Canadian cars anyways. Its nearly always colder than that during the winter here. </font>[/QUOTE]:shrug: That's what the factory service manual says. Anything colder than -29°F for at least 20 seconds will set P0113.
        Matt
        1998 Mystic Teal Camaro M5
