Ok, finaly narrowed it down to lifters. It's just a ticking and its driving me insane. Just wondering what lifters I should order. I'm looking for something good, not cheap because I plan on adding either N20 or boost soon. And while I have my motor torn apart is there anything else I should replace (any other weak points in the motor?). Thanks.
Lifters...
you should go ahead and do your pushrods and if you are planning on a cam later on then you should do your valvesprings. other than that i think the comp cams oe replacement lifters are your only choice but i might be wrong on that (someone will chime in if i am).2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
The 3.8's roller lifters are ticking?
You should be able to fix that with just ajusting them.
There not going to be cheap for a set unless you get them used.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
They're not that expensive, should be less than $200 for a whole set. And to the best of my knowledge, T is correct about them being the only ones available, unless you wanna get stock replacements from gmpartsdirect.com. Trust me, you definitely don't want that because I've already priced them.
I plan to get a set as part of my top-end engine rebuild this year, along with new stainless valves, P & P heads and intakes manifolds, Intense or SLP rocker arms, pushrods, valvesprings, etc.2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
comp cams 105# springs and intense lightweight pushrods.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
...Just curious as to "what" was the prob. with your lifters to decide you needed a new set?
...where they worn flat and/or convex at the base?
...also correct me if im wrong, but if your gonna replace your lifters, you should plan on a new cam as well.---94 Camaro-L32--- <br />\"Don\'t hate the playr, Hate tha GAME!!\" <a href=\"http://members.cox.net/jeanda_sd/SD_L32/SD300L32.jpg\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/SD300L32.jpg</a> <br /> <a href=\"http://members.cox.net/jeanda_sd/SD_L32/100_0022.JPG\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/100_0022.JPG</a> <a href=\"http://members.cox.net/jeanda_sd/SD_L32/L32flipmode.wmv\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/L32flipmode.wmv</a>
...also correct me if im wrong, but if your gonna replace your lifters, you should plan on a new cam as well.94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
i think that would be fine for N20 but talk to james to be sure. if you want to see some bigger gains with the juice get some pnp heads (abbott seem really good and are very reasonable). In fact it would probably be cheaper to put a set of abbot heads on than a cam since you will already be working on the heads when you are doing your valvetrain.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Originally posted by T-Punk:
In fact it would probably be cheaper to put a set of abbot heads on than a cam since you will already be working on the heads when you are doing your valvetrain.Matt
1998 Mystic Teal Camaro M5
Comp. Cams 105 springs, Comp. OEM lifters (like $96), and Comp. Hi-Tech Rods.2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
Originally posted by blacksport:
Comp. OEM lifters (like $96)Matt
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....4 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.4 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
